Flat wall mounts for IAP-205-US
  • 1.  Flat wall mounts for IAP-205-US
    Posted Sep 30, 2015 07:20 PM
    Hi everybody,
    I'm looking for a flat wall mount for an IAP-205.  In the IAP-205's datasheet, I've found these 2 wall mounts:
    AP-200-MNT-W2
    AP-220-MNT-W1
    The AP-220-MNT-W1 is exactly the kind of mount I'm looking for, but when I look either of those up in various distribution channels, they both don't state compatibility with the IAP-20x series.
    Has anybody else used the AP-220-MNT-W1 with an IAP-205, or have definitive information that the two are compatible?
  • 2.  RE: Flat wall mounts for IAP-205-US
    Posted Sep 30, 2015 07:33 PM
    The W1s will work with all 3 200 variants.
    Tim
  • 3.  RE: Flat wall mounts for IAP-205-US
    Posted Oct 01, 2015 07:46 PM
    Thank you, Tim!
    For any others who might be wondering, I'll reply if I encounter any issues or oddities.
