Use the boot-loader command to upgrade the software from 23XX to
24XX on both switches in the IRF domain, rather than using the issu command. After installing R2432P06, reboot both switches.
Check the FLASH for free space and clean up before ftp loading the new .ipe file to flash
<>dir slot1#flash:
<>dir slot2#flash:
<>delete /unreserved slot1#flash:filename.ext
<>boot-loader file flash:/5700-CMW710-R2432P06.ipe slot ?
<1,2> Slot number
<>boot-loader file flash:/5700-CMW710-R2432P06.ipe slot 2 main <cr>
<>boot-loader file flash:/5700-CMW710-R2432P06.ipe slot 1 main <cr>
reboot
