Flexradio APs
  • 1.  Flexradio APs
    Posted Oct 24, 2017 11:57 AM
    We've got some AP-203H units with the flexradio wotnot. Does anybody know how to configure these as 2x2 single band APs within a controller?
    I've had a quick look around and nothing has jumped out at me, but I'm very happy to be pointed towards documentation I've missed.
    I've tried disabling a radio, and I end up with a single stream AP with one disabled radio, so there's something else that needs to happen.
  • 2.  RE: Flexradio APs
    Posted Oct 24, 2017 12:05 PM
    Are you running them as Instant, AOS 6.5, or AOS 8.2?
  • 3.  RE: Flexradio APs
    Posted Oct 24, 2017 12:52 PM
    AOS on version 6.5.4.0 at the moment.
  • 4.  RE: Flexradio APs
    Posted Oct 24, 2017 04:53 PM
    The AOS user guide has a section called "Enabling Flexible Radio".
  • 5.  RE: Flexradio APs
    Posted Aug 06, 2019 07:14 PM
  • 6.  RE: Flexradio APs
    Posted Aug 06, 2019 11:26 PM
    There's not much to it, the 203 series support flexradios that operate either 2x2 single band or dual-band in 1x1. If you want to define that behavior, within the AP system profile you can elect the flex radio mode as 2.4Ghz only, 2.4Ghz and 5Ghz, or 5Ghz only. Table 112 is where it's at for the UG I have on my laptop
