Floor plan image compression
  • 1.  Floor plan image compression
    Posted Feb 10, 2017 11:15 AM
    I have a high quality PDF of a building floor plan that when I open in Adobe PDF reader looks great. When I upload the floor plan to Aruba Airwave 8.2.3 VisualRF it seems it's compressed so much so that I can't read the room numbers. This makes placing AP's tough. I've also tried saving the file as a jpeg and uploading this but get the same result.Is there any way to turn down the compression or anything?
  • 2.  RE: Floor plan image compression
    Posted Feb 10, 2017 11:47 AM
    I would advise to just make the image a little smaller by editing it with some image editing software.
  • 3.  RE: Floor plan image compression
    Posted Feb 10, 2017 12:40 PM
    I ran into this problem a couple years and found a software program to help with converting PDFs into high-quality PNG files. It's called "ImageMagick" - you'll also want the recommended GhostScript - http://imagemagick.sourceforge.net/http/www/windows.html
    It's great for converting individual PDFs or in-bulk via command-line. I would experiment with some of the values in the following discussion - http://stackoverflow.com/questions/6605006/convert-pdf-to-image-with-high-resolution
    - Density - I tested various density values (some were too blurry/some were worse than a simple PDF to JPEG conversion) - but found good success at 600 - this does create larger files. I had tried 300 per the stackoverflow link - but I think had problems with that value.
    - Rotate by - 90 degrees
    - Trim excess space
    - Flatten - remove transparency layers (I noticed without this some of my imports into Airwave would show up completely black)
    Individual Conversion:
    convert -density 600 -rotate -90 -trim -flatten <source-pdf>.pdf <dest-image>.png
    Bulk Conversion
    mogrify -density 600 -rotate -90 -trim -flatten -format png *.pdf
