@jmikola :
Can find some resources SDN Dev Cente's Resources Corner, "REST API and Security"
Inlcuding one sample json for creating flow ( picked from the above resource )
"flow": {
"priority": 30000,
"idle_timeout": 60,
"match": [
{"eth_type": "ipv4"},
{"ipv4_src": "10.0.0.1"},
{"ipv4_dst": "10.0.0.22"},
{"ip_proto": "tcp"},
{"tcp_dst": "80"}
"actions": [{"output": 6}]
Hope that helps
-J
ps: The FTP site is probably accessible to select beta audience, as per what can be made out from other posts in this forum....?
