last person joined: 3 hours ago
For the Beginner - Aruba Instant - IAP - Basic setup
This thread has been viewed 23 times
  • 1.  For the Beginner - Aruba Instant - IAP - Basic setup
    Posted Jul 06, 2012 12:25 PM
    For review
    MJR
    Attachment(s)
  • 2.  RE: For the Beginner - Aruba Instant - IAP - Basic setup
    Posted Dec 09, 2014 09:32 PM
    This is a very helpful document.  I've been looking for something at this level that walks through setting up a wired network that connects to the Instand AP and then on to a cable modem.
    Do you know if such a thing exists?
    Thanks in advance.
  • 3.  RE: For the Beginner - Aruba Instant - IAP - Basic setup
    Posted Aug 16, 2017 04:52 PM
    How can I use WebUI to generate a CSR?
  • 4.  RE: For the Beginner - Aruba Instant - IAP - Basic setup
    Posted Aug 16, 2017 09:32 PM
    You cannot generate a CSR with Instant.  You can generate one offline with Open SSL.
    https://community.arubanetworks.com/t5/Controller-less-WLANs/ArubaOS-Default-Certificate-Revocation-FAQ-Instant/ta-p/275814
  • 5.  RE: For the Beginner - Aruba Instant - IAP - Basic setup
    Posted Aug 16, 2017 11:42 PM
    OK, thank you. I was confused from reading this text in the manual:
    Obtaining a Server Certificate
    Best practices is to replace the default server certificate in the controller with a custom certificate issued for your site or domain by a trusted CA. To obtain a security certificate for the controller from a CA:
    1. Generate a Certificate Signing Request (CSR) on the controller using either the WebUI or CLI.
  • 6.  RE: For the Beginner - Aruba Instant - IAP - Basic setup
    Posted Aug 16, 2017 11:52 PM
    isn't there some sort of easy way such as to open a table and fill in the blank spaces or some other easy way to compose the text and then export the string to send to the CA? I see the instructions for CLI and the text string is so cryptic.
  • 7.  RE: For the Beginner - Aruba Instant - IAP - Basic setup
    Posted Aug 17, 2017 04:50 AM
    Can you point to the text in the Instant AP manual that says this?  It looks like those are instructions from the Campus Controller manual, where you can actually create a CSR.  Instant APs do not allow you to create a CSR.  There are instructions on how to create a CSR with OpenSSL here:  http://community.arubanetworks.com/t5/Controller-less-WLANs/How-to-Create-a-Certificate-for-Instant-Captive-Portal-using/ta-p/277025
