Force DHCP overwriting Static
  • 1.  Force DHCP overwriting Static
    Posted May 14, 2014 11:37 AM
    Is there a way to force clients to take the DHCP you are handing over something they staticly assigned themselves? Even if the client is trying to specify an IP that is within your valid DHCP Range.
    Example:
    DHCP Range 192.168.0.100-.200
    Client statics 192.168.0.199
    Thank you,
    -Oranjestad
    Environment
    Clearpass - CP-HW-5K
    Version 6.2.6.62196
    Controller - Aruba7210-US
    Version 6.3.1.6
    AP225
    #AP225
  • 2.  RE: Force DHCP overwriting Static
    Posted May 14, 2014 11:39 AM
    Enable Enforce DHCP in your AAA profile.
    Also, be sure your validuser ACL is up to date with the IP space you are using for clients.
  • 3.  RE: Force DHCP overwriting Static
    Posted May 14, 2014 02:50 PM
    That was it, I should have explored some more in the settings.
    Thanks Cappalli!
