Force EIRP and Channel for 802.11a .
  • 1.  Force EIRP and Channel for 802.11a .
    Posted Nov 29, 2012 03:51 PM
    Hi everyone,
    For a site survey, we want to be able to force a Channel and a signal force.
    It work perfectly for me with the 802.11g in those section :
    RF Management
       802.11g radio profile
          Transmit EIRP : 15 (Exemple)
          Channel : 10 (Exemple)
    RF Management
          Adaptive Radio Management (ARM) Profile
             Assignement : Disable
    Then 1-2 minutes after, in the dash board, I can see that the Channel et EIRP are force.
    But when I do the same for 802.11a (in the 802.11a radio profile of course), it doesn't work. The value that I want is :
    EIRP : 15
    Channel :140
    Anyone have an idea on that ?
    Thanks.
  • 2.  RE: Force EIRP and Channel for 802.11a .
    Posted Nov 29, 2012 07:27 PM
    Is channel 140 allowed on your regulatory domain for that access point?
    show ap allowed-channels ap-name <name of ap>
  • 3.  RE: Force EIRP and Channel for 802.11a .
    Posted Nov 30, 2012 07:37 AM
    Thanks it was the problem...
    Don't know why I was stick on that channel. I could try to see if another one was ok..
  • 4.  RE: Force EIRP and Channel for 802.11a .
    Posted Aug 14, 2013 01:19 PM
    I was just wondering how the transmit EIRP in the radio profile and Min/Max Tx EIRP settings relate?  For example - Does the Transmit EIRP setting in the radio profile takes precedence over the Min/Max Tx EIRP setting in the ARM profile?  When would you use the setting in the radio profile?
    Thanks in advance.
    -Luis
  • 5.  RE: Force EIRP and Channel for 802.11a .
    Posted Aug 14, 2013 01:21 PM
    The TX EIRP in the radio profile is used when:
    - The Access point is fresh out the box and just contacted the controller (this will be the initial power)
    - The ARM setting is to None.
  • 6.  RE: Force EIRP and Channel for 802.11a .
    Posted Aug 14, 2013 01:23 PM
    Thanks for the explanation!
