last person joined: 8 hours ago
Force SMTP traffic over Management Port
  • 1.  Force SMTP traffic over Management Port
    Posted Mar 28, 2019 04:09 PM
    Hello everyone.
    I´m implementing a clearpass server using both, management and data ports.
    Since the SMTP server is reachable just over the management network i need to redirect the SMTP request to this port.
    Is there a way to do it ?
    obs: at this time i can see the traffic going out over the data port when i send a test e-mail.
    Thiago
  • 2.  RE: Force SMTP traffic over Management Port
    Posted Mar 28, 2019 04:11 PM
    No. Generally speaking, if you’re going ot use both interfaces, they both should not have default routes to the internet.
  • 3.  RE: Force SMTP traffic over Management Port
    Posted Mar 28, 2019 04:37 PM
    Hello Tim
    Thank you for your quick answer.
    I will configure a static route to the smtp server. This should work according to the attached documentation.
    regards,
    Thiago
