Hi community,
do you know if its possible to restric access to only one SSID for a specific operating system ?
An exemple : Android devices can only connect/view SSID "guest".
Thanks for your help
Alexis
You can do some blocking of devices by doing DHCP fingerprinting, but you cannot force devices to connect to an SSID based on operating system.
Ok thanks !
Do you know if there is an Aruba service that can do this kind of function ?
https://www.arubanetworks.com/assets/vrd/AOS-DHCP-FingerPrint-AppNote.pdf
