forgot enable password
  • 1.  forgot enable password
    Posted Nov 15, 2016 12:49 PM
    Dear Airheads Experts!
    I forgot my enable password. I know I can reset it via console. But can I do it via webui with controller wizard, if I know the local admin password? And If I can, is it a good idea in production and is it a reuseable wizard)?
    Thank you in advance for your help!
    Zs
  • 2.  RE: forgot enable password
    Posted Nov 15, 2016 12:55 PM
    Nope, console only I'm afraid.
  • 3.  RE: forgot enable password
    Posted Nov 15, 2016 01:14 PM
    Thank you jrwhitehead!
    So I can't reuse the controller wizard for this? Because in the beginning I can set up the enable password via controller wizard.
    Thank you!
    Zs
  • 4.  RE: forgot enable password
    Posted Nov 15, 2016 03:04 PM
    I think about the following. Could it work?
    Thank you in advance for your reply!
    Zs
  • 5.  RE: forgot enable password
    Posted Nov 16, 2016 04:57 AM
    Hi All,
    I tested it in my lab and it worked via webui with controller wizard.
    So I successfully change the enable password without console connection. It could be useful in some cases, if you know the admin password but you don't know the enable password and the controller is in the datacenter.
    Is there any objection about this solution?
    Thank you!
    Zs
