Forwarding mode (tunnel/bridge) considerations with VOIP
  • 1.  Forwarding mode (tunnel/bridge) considerations with VOIP
    Posted Mar 01, 2017 07:40 AM
    I'm planning a VOIP-focused deployment, and had some questions around the limitations of each forwarding mode.
    I've been looking around the forums here for a while but can only find very outdated information as to what is/isn't supported for each forwarding mode. Is there a more up-to-date summary available that anyone can point me to?
    Many thanks,
  • 2.  RE: Forwarding mode (tunnel/bridge) considerations with VOIP
    Posted Mar 01, 2017 07:47 AM
    If you want detailed voice statistics, I would not consider bridge mode. There is very little visibility in that mode.
  • 3.  RE: Forwarding mode (tunnel/bridge) considerations with VOIP
    Posted Mar 01, 2017 08:06 AM
    Thanks Colin. I know Lync/SFB Heuristics isn't supported on bridge mode either (but we aren't just doing Lync). Other than statistics/visibility, are there are any direct, service-affecting downsides to bridge mode? The customer may push back otherwise, as tunnel mode will require more controllers to be purchased, or for traffic to "trombone" the WAN links.
