Hi team.
I'm trying to get a site to site vpn working from a 9004 AOS10 gateway to Azure. Gateway F/W 10.6 I used Florians guide: https://www.flomain.de/2022/07/azure-site-to-site-vpn-with-an-aruba-gateway/
Unfortunately the IKE policy profile is missing from the instructions (Florian uses Policy 25 which is not a default) and I'm having a hard time matching the options in Azure with the options in gateway config resulting in the tunnel not establishing. The only Aruba Central event I'm seeing: VPN Peer is unreachable. In Azure: not connected.
I tryd both IKE v1 and v2 with both Azure default and custom settings.
Shared Secret is 100% match.
Anyone with a working site to site VPN willing to share the IKE settings used and any other settings not matching Florians guide?
thanks in advance
Erik
