Generate a free public Certificate for captive portal authentication
This thread has been viewed 26 times
  • 1.  Generate a free public Certificate for captive portal authentication
    Posted Jun 21, 2017 08:33 PM
    Hi folks.
    i found this website that enable you to generate a free Certificate for your controller
    https://gethttpsforfree.com/
    you can use this certification with the controller access webpage, captive potral and 802.1X terminition.
     you can found in attachment the procedure to integrate the certification with captive portal and the controller webpage.
    this way you will never get the certification error message.
    Regards
    Attachment(s)
    pdf
    Apr MHC Aruba Cert.pdf   661 KB 1 version
  • 2.  RE: Generate a free public Certificate for captive portal authentication
    Posted Jun 21, 2017 08:36 PM
    That’s a very bad idea. The certificates are only valid for 90 days.
    You can get a public certificate that’s valid for 1 year for $4.99.
    It’s not recommended to use LetsEncrypt certificates for these functions, especially EAP server certificates.
