Generate a report Network usage by SSID with a new option to choose?
  • 1.  Generate a report Network usage by SSID with a new option to choose?
    Posted Oct 28, 2014 10:09 AM
    I would like to generate a report that gives me a list of the number of users for every SSID in a selected interval for every especific group only doing one report.
    I've tried to define a report with:
    • Network Usage: Usage by SSID,
    This report only let me work with those options
    • Interval
    • SSID
    • Max Clients
    • Avg Usage Out
    • Max Usage In
    • Max Usage Out
    • Avg Clients
    • Avg Usage In
    Using this kind of template I cannot separate traffic of every group that I have. Is there any chance to introduce in that template a new option like "group"??
    Thank you,
  • 2.  RE: Generate a report Network usage by SSID with a new option to choose?
    Posted Oct 30, 2014 11:56 PM
    How would you group your users ?
  • 3.  RE: Generate a report Network usage by SSID with a new option to choose?
    Posted Oct 31, 2014 09:44 AM
    My objective is to put a new option to the options that give me "Network Usage: Usage by SSID":
    • Interval
    • SSID
    • Max Clients
    • Avg Usage Out
    • Max Usage In
    • Max Usage Out
    • Avg Clients
    • Avg Usage In
    So I need to have those options:
    • Interval
    • SSID
    • Max Clients
    • Avg Usage Out
    • Max Usage In
    • Max Usage Out
    • Avg Clients
    • Avg Usage In
    • Group
    Is this possible?
  • 4.  RE: Generate a report Network usage by SSID with a new option to choose?
    Posted Nov 04, 2014 11:38 PM
    not at this time, this sounds like a feature to file in the ideas portal on the support site.
  • 5.  RE: Generate a report Network usage by SSID with a new option to choose?
    Posted Aug 26, 2019 07:34 AM
    Hello All,
    I have a similar requirement to generate Network usage per SSID in Aruba Central.
    can any one help me.
    sekhar
