last person joined: 8 hours ago
generate access point license from HPE order # on Aruba license management service
  • 1.  generate access point license from HPE order # on Aruba license management service
    MVP
    Posted Nov 25, 2022 02:12 AM
    When I go to Aruba license management service, and do self-generate access point licenses from HPE order #, its not clear there:
    - should I use serial number of my mobility master ( in this case can use serial number of  primary mobility master or secondary is also okay), as licenses afterwards are assigned via mobility master
    - should I use serial number of local WLCs​ ?
  • 2.  RE: generate access point license from HPE order # on Aruba license management service
    Posted Nov 25, 2022 05:59 AM
    In a mobility conductor (MM) deployment, you license on the (primary) MCR not on the controller.
