Generate Heat map using Aruba controller?
  • 1.  Generate Heat map using Aruba controller?
    Posted Jan 09, 2014 09:15 PM
    I'm new to Aruba networks and i'm trying to figure out if I can use Aruba controller to generate the heat map, like the mobility controller 6000?
    Like for planning or troubleshooting? Do I need to and Airwaves server to do those? I know Cisco need Prime infrastructure to do heat maps...
    /S
  • 2.  RE: Generate Heat map using Aruba controller?
    Posted Jan 09, 2014 10:34 PM
    For a predictive heat map, you can use our VisualRF softare found on the support site.  It's a free tool for predictive heat maps.
    If the controller was below 6.3, we had this tool embedded within the controller.  However, our current recommendation is to use Airwave for real time heat mapping.
  • 3.  RE: Generate Heat map using Aruba controller?
    Posted Jan 09, 2014 10:43 PM
    Thanks, I will try to find the visualrf software.
    If the controller running code 6.3 above, the heatmap feature is gone? If so, why? I would need a airwaves server for heatmap?
  • 4.  RE: Generate Heat map using Aruba controller?
    Posted Jan 09, 2014 10:44 PM
    It was removed to make room for other features like application visiblity and Airgroup...
    Yes - you would need airwave
