Generate Random Password with Clearpass
  • 1.  Generate Random Password with Clearpass
    Posted Jan 17, 2017 09:57 AM
    first time poster. I’m using the REST API to create guest accounts. Lately I wanted to use the random_password feature but with no success:
    ( user is Super Administrator )
    • I create a guest account from the admin panel then view it and can read its password - All GOOD.
    • I create a guest using the API. The guest is created ( server answers 201 ). No password field is specified. When accessing the admin panel I get “Error decrypting string” if the show password options is selected.
    This is my user when calling /guest in POST
      "create_time": "",
      "current_state": "",
      "do_expire": 0,
      "email": "test.testgmail.com",
      "enabled": true,
      "expire_time": "",
      "mac": "",
      "notes": "",
      "role_id": 2,
      "simultaneous_use": 0,
      "sponsor_email": "test1.test@gmail.com",
      "sponsor_name": "test",
      "start_time": "",
      "username": "test.test@gmail.com",
      "visitor_company": "visitor company",
      "visitor_name": "visitor name"
    The error message is attached herewith.
    I would like that a password would be randomly generated for every account and was visible from the admin panel in the “Manage Guest Accounts” section. I’d also like to know if it were possible to use your API to generate a random password.
    Thank you for your support,
    Best Regards,
    Christopher Lacapra
  • 2.  RE: Generate Random Password with Clearpass
    Posted Jan 17, 2017 10:03 AM
    You can use the POST /random-password API call to generate a random password, then you can pass that value into your guest creation call.
  • 3.  RE: Generate Random Password with Clearpass
    Posted Jan 17, 2017 10:20 AM
    Just tried and got
    {"The remote server returned an error: (422) Unprocessable Entity."}
    By sending an empty json. Is there some configuration I must send in that json? like random_password_length or random_password_method?
  • 4.  RE: Generate Random Password with Clearpass
    Posted Jan 17, 2017 10:31 AM
    No, you shouldn't have to send those as it will use the default guest config:
    winux@CAPPY-SP4:/mnt/c$ curl -X POST -H "Authorization: Bearer <redacted>" -H "Content-Type: application/json" -H "Cache-Control: no-cache" -d '' "https://<redacted/api/random-password"
    {"password":"977076"}
  • 5.  RE: Generate Random Password with Clearpass
    Posted Jan 17, 2017 11:24 AM
    Still no luck. Is it possible that the method is not available in my API due to some user restrictions for the user the api has beed created for?
    My request is:
    POST http://clearpass-ip-address/api/random-password HTTP/1.1
    Bearer my-awesome-token
    Host: clearpass-ip-address
    Content-Length: 0
    I get this answer:
    HTTP/1.1 302 Found
    Date: Tue, 17 Jan 2017 16:21:24 GMT
    Server: Apache
    Vary: X-Forwarded-For
    X-Powered-By: PHP/5.6.25
    Location: https://clearpass-ip-address/api/random-password
    Content-Length: 0
    Content-Type: text/html; charset=UTF-8
  • 6.  RE: Generate Random Password with Clearpass
    Posted Jan 17, 2017 11:26 AM
    What version of ClearPass are you running?
  • 7.  RE: Generate Random Password with Clearpass
    Posted Jan 17, 2017 11:31 AM
    ClearPass Guest 6.6.2.33301 on CP-SW-EVAL platform
  • 8.  RE: Generate Random Password with Clearpass
    Posted Jan 17, 2017 11:34 AM
    Please test using the built-in API explorer. If that doesn't work, please open a TAC case.
  • 9.  RE: Generate Random Password with Clearpass
    Posted Jan 17, 2017 11:47 AM
    Can't find that method in the api explorer. :(
  • 10.  RE: Generate Random Password with Clearpass
    Posted Jan 17, 2017 12:51 PM
    Sorry, this was added in 6.6.3.
  • 11.  RE: Generate Random Password with Clearpass
    Posted Jan 18, 2017 04:42 AM
    Thank you!
    Updating Clearpass solved my problem!
    Flagging thread as solved.
