Generating a report to view multiple AP Network Usage
  • 1.  Generating a report to view multiple AP Network Usage
    Posted Feb 20, 2012 05:03 AM
    Hi folks,
    I am using Welcome to AMP™ 7.3.5.
    I am trying to generate a report to see network usage on multiple APs. However I dont know how to enter multiple MAC IDs in the Device Search Filter. Actually I dont know how to seperate those MAC IDs.
    I tried ; then
    I tried , then
    I tried " SPACE"
    I tried them all, they didnt work. Any idea how can I enter multiple AP MAC IDs.
    Thanks in advance.
    Omer
  • 2.  RE: Generating a report to view multiple AP Network Usage
    Posted Feb 20, 2012 11:34 PM
    I think the best way to do this is to place the APs in a group and run the report on the Group (This is on AMP, not the controller).
    -Mike
  • 3.  RE: Generating a report to view multiple AP Network Usage
    Posted Feb 21, 2012 08:54 AM
    Hi Mike,
    thank you so much. It is working..
    best regars.
    Omer
  • 4.  RE: Generating a report to view multiple AP Network Usage
    Posted Feb 21, 2012 10:42 AM
    You can also run a report on any set of APs or clients by clicking "Modify Devices" at the top of a list, selecting some devices, and then running a report (from the choice of actions at the bottom of the list).
    The search filter for reports is meant to be a single query just like the search box in the upper right side of the application.
