Generic SQL with MSSQL Instance
  • 1.  Generic SQL with MSSQL Instance
    Posted Jun 23, 2016 04:27 AM
    Hi all
    I try to connect to a MSSQL Database with the "Generic SQL DB" Source. Unfortunately the SQL Server has an SQL-Instance with the name "BMS" and I can't add it to the connection information. Adding it to the Servername like "ip\BMS" doesn't work as well.
    Has anybody an idea?
    Regards
    Manuel
  • 2.  RE: Generic SQL with MSSQL Instance
    Posted Jun 23, 2016 04:29 PM
    So its not always just that simple as you found out.
    FIrstly did you change the default driver on the PRIMATY tab to MSSQL?.... then it can depend a lot on how the underying MS-SQL DB is setup and configured. In the link below is an example of how I did a SQL connection to a BlackBerry MS-SQL DB.... hoefully this might give you a few pointers.....
    Tech Note: ClearPass Enterprise Mobility Management Integration V5
    HTH
  • 3.  RE: Generic SQL with MSSQL Instance
    Posted Jun 24, 2016 09:25 AM
    Hi danny
    That doesnt really help. but in the meantime I fixed the dynamic TCP port of the Named-Instance and use this directly. Works fine for me.
    Thanks & Regards
    Manuel
