last person joined: 3 hours ago
Get Eval License
  • 1.  Get Eval License
    Posted May 05, 2013 09:09 AM
    how can I get Evaluation licenses for my mobility Controller ??
  • 2.  RE: Get Eval License
    Posted May 05, 2013 09:18 AM
    You need to talk with your partner for it.
    If you are a partner then you need to open a support ticket so they activate on your account the power of create evaluation keys in your elicensing account
    Cheers
    Carlos
  • 3.  RE: Get Eval License
    Posted May 05, 2013 09:35 AM
    You should consult with your local SE , he would be able to generate those for you.
    Or you could go to the Licensing Management website if you have access to it :
    https://licensing.arubanetworks.com/
    Hope this helps
  • 4.  RE: Get Eval License
    Posted May 09, 2013 04:34 AM
    I have email the support and they have create an account for me
    problem solved
    thinks
