Network Management
Get Serial Numbers for all Switches from Core
  • 1.  Get Serial Numbers for all Switches from Core
    Posted Feb 14, 2024 02:14 PM
    Is it possible to get the serial numbers of all the switches connected to HPE Aruba 5400Rzl2?
    Thanks.
  • 2.  RE: Get Serial Numbers for all Switches from Core
    Posted Feb 15, 2024 01:52 AM
    Hi, it is not possible directly on the CLI. The only information passed between attached switches is via LLDP which does not include the serial number.
    The nearest you can get is to use LLDP to gain the chassis ID which is often the base MAC address for the attached switch. If you have a table somewhere with that or perhaps just the hostname you could work it out.
