Developer
Getting dot1x error when creating WLAN via api call
  • 1.  Getting dot1x error when creating WLAN via api call
    Posted Feb 20, 2019 04:31 AM
    Hi Team,
    I am getting the following error when I try to create WLAN via API call:
    Error: dot1x profile needs to be enabled in aaa profile to support opmode, ssid profile referring this is :vssid123
    Scenario: First I created WLAN named vssid123 manually on the aruba wireless controller with security as open. Now I am trying to update the WLAN and trying to change the security to personal(setting a password) using API call.
    Sample code:
    $sessionId = createSession();
    $ssid = '{
    "profile-name": "vssid123",
    "ssid_enable": {},
    "essid": {
    "essid": "vssid123"
    "wpa_passphrase": {
    "wpa-passphrase": "secretPSK5"
    "opmode": {
    "wpa2-psk-aes": true
    //add ssid profile
    $url = 'https://113.x.x.x:7707/v1/configuration/object/ssid_prof?config_path=%2Fmm%2Fmynode&UIDARUBA='.$sessionId;
    I am getting the same error using the swagger as well.
    Any suggestions?
    Amardeep
  • 2.  RE: Getting dot1x error when creating WLAN via api call
    MVP GURU
    Posted Feb 20, 2019 08:21 AM
    it is like the GUI !
    You need to specifiy a dot1x profile to your AAA Profile before set a PSK (there is a default dot1x-wpa if remenber for this)
  • 3.  RE: Getting dot1x error when creating WLAN via api call
    Posted Feb 20, 2019 09:11 AM
    Ok.
    But in the API calls for creating WLAN we make the first call to ssid_prof object where we can't set this attribute. The second call is made to the virtual_ap object where we cann add this attribute.
    I am getting the error in the response to the first call to ssid_prof object.
  • 4.  RE: Getting dot1x error when creating WLAN via api call
    MVP GURU
    Posted Feb 20, 2019 02:40 PM
    it don't create already the VirtualAP profile ?
  • 5.  RE: Getting dot1x error when creating WLAN via api call
    Posted Feb 26, 2019 07:29 PM
  • 6.  RE: Getting dot1x error when creating WLAN via api call
    Posted Feb 26, 2019 07:48 PM
    As mentioned by alagoutte, you will need to create a dot1x authentication profile and add it to a AAA profile for converting an open ssid to a PSK ssid.
    Find the API call below, for converting to a PSK ssid:
    Method:
    POST
    URL:
    $url = 'https://113.x.x.x:7707/v1/configuration/object?config_path=%2Fmm%2Fmynode&UIDARUBA='.$sessionId;
    Request Body (JSON): Multiple Endpoints
    "ssid_prof": [{
    "ssid_enable" : {},
    "essid": {
    "essid": "vssid123"
    "wpa_passphrase": {
    "opmode": {
    "dot1x_auth_profile": [{
    "aaa_prof": [{
    "dot1x_auth_profile": {
    "virtual_ap": [{
    "aaa_prof": {
    "vlan": {
    "vlan": "1"
    "ssid_prof": {
    "ap_group": [{
    "profile-name": "default",
    "virtual_ap": [{
    Note:
    - Multiple endpoints are hit in the same api call like ssid_prof, do1x_auth_prof, aaa_prof, virtual_ap, ap_group to create/edit various profiles
    - Only ssid_prof, dot1x_auth_profile and aaa_prof are needed to achieve the desired result, however virtual_ap and ap_group are added in case you need it
    - Change vlan and ap-group name in the request body as applicable
    Jay
