last person joined: 3 hours ago
Getting error in EAP-TLS authentication.
  • 1.  Getting error in EAP-TLS authentication.
    Posted Mar 14, 2024 09:52 AM
    I am getting many failed connection with the below error . Is anyone experience the same behavior . Help me with the suggestions and fix
  • 2.  RE: Getting error in EAP-TLS authentication.
    Posted Mar 14, 2024 09:59 AM
    Hi
    What type of client get this error? As the error message states "fatal alert by client" the error is on the client side.
    Some additional information would also be good to know:
    • What version of ClearPass are you running?
    • Have anything changed in the environment like updates on the client side or ClearPass?
    • Do you also have working EAP-TLS authentications?
    Best Regards
    Jonas Hammarbäck
    Aranya AB
  • 3.  RE: Getting error in EAP-TLS authentication.
    Posted Mar 14, 2024 02:43 PM
    What type of client get this error? Mobile phones
    • What version of ClearPass are you running? 6.10.8
    • Have anything changed in the environment like updates on the client side or ClearPass?No
    • Do you also have working EAP-TLS authentications? Yes
  • 4.  RE: Getting error in EAP-TLS authentication.
    Posted Mar 15, 2024 08:55 AM
    May be best to work with TAC on this. I've seen multiple reasons, like server certificate not trusted, no client certificate enrolled to the client device, authorization servers that were unreachable or take a lot of time. There is something that the client does not like. It may be good to find what the failing clients have in common (same OS, new enrolled, renewed certificate, or so).
