Wired Intelligent Edge
Getting pattern drop while pinging to Aruba switch from cisco switches
  • 1.  Getting pattern drop while pinging to Aruba switch from cisco switches
    Posted May 18, 2023 04:54 PM
    Hi Team,
    Getting pattern drop while pinging to Aruba switch from cisco switches. tried with extended ping but the result is same.
    is this a default behavior of CX switches for ICMP packets???
  • 2.  RE: Getting pattern drop while pinging to Aruba switch from cisco switches
    Posted May 25, 2023 11:40 AM
    Had to lookup what pattern drop is (something like !!!.!!!.!!!.!!!.!.!!!.!!!.!!!.!!!.!!!.!!!.!!!.! so few success, fails, successes again), but when I did the possible answer is in there as well. This probably has to do with CoPP (Control Plane Policing), and yes that is on by default on CX. The AOS-CX CoPP Guide can probably get you further if you need to look up more or want to tweak the configured values.
