Getting specific SSID reports
  • 1.  Getting specific SSID reports
    Posted Apr 30, 2018 10:27 AM
    Can anyone give me the steps to getting a report from an AP of who is on a specific SSID?  I know you use the mobility controller.  On the dashboard go to Access Points and then into each AP from there.
    But I have 451 APs and do not want to have to go into each one individually to see who is using which ssid.  I am sure there has to be a simplier solution than going to each AP individually to get that information.
    Thank you!!
  • 2.  RE: Getting specific SSID reports
    MVP EXPERT
    Posted Apr 30, 2018 10:31 AM
    Its not a report as such but the below command will show you:
    #show user-table ap-name XXXX <-- Users Per AP
    #show user-table essid XXXX <-- Users Per SSID
    If you want reporting functionality then you would need to consider something like AirWave.
  • 3.  RE: Getting specific SSID reports
    Posted Apr 30, 2018 11:28 AM
    Ok thank you.  I also have Airwave.  Could you guide me using that program?
  • 4.  RE: Getting specific SSID reports
    Posted Apr 30, 2018 11:35 AM
    Thank you!!
    To be clear, do you want to know how many people are on each SSID?
  • 5.  RE: Getting specific SSID reports
    Posted Apr 30, 2018 11:40 AM
    No I am needing to see what MAC addresses are on each SSID.  We are a college campus and need to make sure students are not on the administrative SSID.
  • 6.  RE: Getting specific SSID reports
    Posted Apr 30, 2018 11:46 AM
    Fair enough.  How would you want that formatted so that it is useful for you?
  • 7.  RE: Getting specific SSID reports
    Posted Apr 30, 2018 11:51 AM
    I think just the speceific SSID and MAC address connected to that SSID.
    I could then cross reference those mac addresses with our netreg system to look for student devices.
  • 8.  RE: Getting specific SSID reports
    Posted May 01, 2018 01:01 PM
    Still hoping someone can help me.  PLEASE and THANK YOU!!!!!!
  • 9.  RE: Getting specific SSID reports
    MVP EXPERT
    Posted May 01, 2018 02:28 PM
    Have you tried the previous commands posted? These will give you what MAC is connected to what SSID. It won’t be formatted but it is a starting point :)
    Sent from my iPhone
  • 10.  RE: Getting specific SSID reports
    Posted May 01, 2018 03:52 PM
    Do you mean these commands:
    using
    show user-table essid XXXX comes back with 0/0 entries
    using
    show user-table ap-name requires going through every AP which I could do using Mobility Controller but I have 451 and am trying to find an easier way to get the information I am needing.
  • 11.  RE: Getting specific SSID reports
    MVP EXPERT
    Posted May 01, 2018 04:05 PM
    *edit* are you running this from the controller where the AP’s terminate?
  • 12.  RE: Getting specific SSID reports
    Posted May 01, 2018 04:09 PM
    I did and this is the result:
  • 13.  RE: Getting specific SSID reports
    Posted May 01, 2018 04:10 PM
    Yes using putty
  • 14.  RE: Getting specific SSID reports
    Posted May 01, 2018 04:32 PM
    Are there access points on that controller?  When you type "show ap essid" do you see anything?
  • 15.  RE: Getting specific SSID reports
    Posted May 01, 2018 04:53 PM
    Yes, I have 451 AP on the controller that I am using putty to run the command "show ap essid" and this is what I get when I put in the SSID I am trying to get information from:
  • 16.  RE: Getting specific SSID reports
    Posted May 01, 2018 04:58 PM
    I GOT IT TO WORK FINALLY!!!!  USER ERROR!!!
    THANK YOU ALL SO SO SO MUCH!!!!!!!!!!!!!!
  • 17.  RE: Getting specific SSID reports
    Posted May 01, 2018 03:14 PM
    Like Zalion said, can you please tell us what is your workflow for doing the comparison and we might be able to give you and idea of what you should look at?
