Developer
last person joined: 13 days ago
Gettings started with NAPALM and PYAOSCX
This thread has been viewed 19 times
  • 1.  Gettings started with NAPALM and PYAOSCX
    Posted Dec 09, 2023 09:37 PM
    Hi there,
    I'm trying to get started with the automation tools at: https://developer.arubanetworks.com/aruba-aoscx/docs/using-the-aos-cx-napalm-drivers
    But I'm receiving an error with the PYAOSCX module when I attempt to issue the following command to NAPALM on the command-line on my automation server in my venv:
    python3 -c "from napalm_aoscx.aoscx import AOSCXDriver"
    (venv) [root@server netbox]# python3 -c "from napalm_aoscx.aoscx import AOSCXDriver"
    Traceback (most recent call last):
      File "<string>", line 1, in <module>
      File "/opt/netbox-3.6.1/venv/lib/python3.10/site-packages/napalm_aoscx/__init__.py", line 16, in <module>
      File "/opt/netbox-3.6.1/venv/lib/python3.10/site-packages/napalm_aoscx/aoscx.py", line 52, in <module>
        from pyaoscx import session, interface, system, common_ops, port, lldp, mac
    ImportError: cannot import name 'system' from 'pyaoscx' (/opt/netbox-3.6.1/venv/lib/python3.10/site-packages/pyaoscx/__init__.py)
    My virtual environment contains the necessary pre-requisite packages (output edited for brevity):
    (venv) [root@server netbox]# pip freeze
    napalm==4.1.0
    napalm-aruba-cx==0.1.4
    napalm-arubaos-switch==0.2.0
    pyaoscx==2.5.1
    requests==2.31.0
    urllib3==2.1.0
    I already tried reinstalling the packages by issuing:  pip3  install --upgrade --force napalm-aruba-cx napalm-arubaos-switch
    to no joy. Anyone have any ideas?
  • 2.  RE: Gettings started with NAPALM and PYAOSCX
    MVP GURU
    Posted Dec 11, 2023 07:21 AM
    You need to use pyaoscx v1.0.0
    it is not yet(...) compatible with pysoascx 2.x
    https://github.com/napalm-automation-community/napalm-aruba-cx
    Note that the current version of this driver utilizes pyaoscx v1 only. Future versions of this driver will be compatible with pyaoscx v2
    PowerArubaCL: Powershell Module to use Aruba Central
    ACEP / ACMX #107 / ACDX #1281
  • 3.  RE: Gettings started with NAPALM and PYAOSCX
    Posted Dec 11, 2023 07:42 AM
    Wow... Can't believe that I missed that.
    So, I issued the following command in my venv: pip3 install pyaoscx==1.0.0 --force-reinstall -v
    After which, everything is fine. Thanks Alexis
  • 4.  RE: Gettings started with NAPALM and PYAOSCX
    MVP GURU
    Posted Dec 11, 2023 10:05 AM
    No problem :)
    (yes it is missing on developer aruba page.. or need to update napalm for support pyaoscx v2 also...
