Network Management
Globa setting for telnet / ssh credentials
  • 1.  Globa setting for telnet / ssh credentials
    Posted Jul 19, 2018 10:16 AM
    New to Airwave. I am currently using it to monitor my HP / Aruba switches. as I have started to bring in my locations switches into thier repective groups I am getting a lot of mismatch alerts. the majortiy of them complaining about this. "Error(Telnet/SSH Error: No username specified) " I would prefer to not enter this information in per error / switch. Where can I set this globally please? Thanks.
  • 2.  RE: Globa setting for telnet / ssh credentials
    Posted Jul 19, 2018 10:39 AM
    Device Setup> Communication> Aruba> Edit.
  • 3.  RE: Globa setting for telnet / ssh credentials
    Posted Jul 19, 2018 10:42 AM
    I'm sorry. I forgot to mention that I had already done that. It seems to be being ignored. So I thought there may be somewhere else to do it. I am on 8.2.6.1
  • 4.  RE: Globa setting for telnet / ssh credentials
    Posted Jul 19, 2018 11:34 AM
    The Device Setup -> Communications page is used when you first add the device (either manually or through discovery).  If the devices are already added, then you need to bulk edit from the Devices list view.
    go to Devices list
    create a view that shows only the devices with Config = Error
    click the pencil at the top right of the list table to get bulk edit options
    check all the devices that need updating
    from the Device actions drop down, select "Update the credentials used to communicate with these devices", click update
    it should take you to a view that prompts for the creds, input creds and click update
    it'll then take you to a confirmation page, apply changes now
  • 5.  RE: Globa setting for telnet / ssh credentials
    Posted Jul 19, 2018 11:37 AM
    I did this already to fix the ones that were already wrong. What I am looking for is to not to have to do this in the future as I add more switches to the system. Thanks.
  • 6.  RE: Globa setting for telnet / ssh credentials
    Posted Jul 19, 2018 11:48 AM
    New switches should observe the Device Setup -> Communication settings - unless you type something else in the fields at time of adding.
  • 7.  RE: Globa setting for telnet / ssh credentials
    Posted Jul 19, 2018 11:57 AM
    presuming that this is the correct one for HP Procurve / HP Aruba switches I have already set that. device setup/communication/Aruba I had also done the same for the HPE  just to cover my bases.
  • 8.  RE: Globa setting for telnet / ssh credentials
    Posted Jul 19, 2018 12:20 PM
    It depends on which switch models, there's several categories under Device Setup -> Communication for various Aruba / HPE models:
    Aruba (covers general Aruba branded)
    Aruba MAS
    ArubaOS Switch
    ArubaOS-CX Switch
    HPE (covers general HPE branded)
    HPE OfficeConnect Switch
    I've also filed a few defects to simplify this, and to address that there's not a 1-1 mapping between Device Setup -> Add selection vs Device Setup -> Communication options.
  • 9.  RE: Globa setting for telnet / ssh credentials
    Posted Jul 19, 2018 01:15 PM
    So I shotgunned it and did all the ones you listed:) One of those fixed it. I just pulled in another school of 23 switches with no SSL credentials issue. Thanks!
