After GH and my iPhone are connected to the same wifi, but they cannot connect to each other. Inter-user traffic is allowed. If I use an Android, it works. Is there something that needs to be enabled?
AFAIK the same protocols and ports are used for both apps so, I'd recommend resetting the google home app on the iphone.
This is being done with fresh install of the GH app, and reset of GH device.
If you perform the initial setup of the Google Home with Android with full setup-process completed - are you able to use your iPhone to connect to the Google Home on the same SSID? I ask because I've seen a large difference between the the inital setup of Android and iOS devices - with iOS being frustrating to get setup.Also is this controller-based and are you making use of AirGroup?
