Granularity for bandwidth-contracts ? (manual only contains the range 256k - 2000M)
  • 1.  Granularity for bandwidth-contracts ? (manual only contains the range 256k - 2000M)
    Posted Jul 02, 2015 01:04 PM
    Hi all,
    The Aruba OS (controller based) supports bandwidth contracts which can be binded to user roles.
    Does anyone know the granularity for those bandwidth values ?
    The range starts with 256 kbit/s, and what is the next possible bandwidth value ?
    and does the granularity depend on the bandwidth value? (e.g. 1M bandwidth and 100M bandwidth value; do they have the same granularity ?)
    many thanks for your answer.
    Rolf
  • 2.  RE: Granularity for bandwidth-contracts ? (manual only contains the range 256k - 2000M)
    Posted Jul 02, 2015 01:11 PM
    (Aruba7640-US) (config) #aaa bandwidth-contract test kbits ?
    <256..2000000>          Bandwidth in kbits/seconds
  • 3.  RE: Granularity for bandwidth-contracts ? (manual only contains the range 256k - 2000M)
    Posted Jul 02, 2015 01:19 PM
    Hi Colin,
    thanks for your answer. but what does this mean concerning granularity?
    Usually the granularity of the built-in traffic-policer is not that small that we can increment die bandwidth values in steps of 1kbps -right?
    If we configure 256kbps bandwidth, what would be the second lowest bandwidth ? (384kbis or 512kbps, or .. )
    and if I configure a bandwidth-contract value of 100Mbps, what would be the next higher value?
    (I don't beliebe 100.001Mbps - which actually would not make sense to increment in such small steps... )
    thanks in advance for your answer.
    Rolf
  • 4.  RE: Granularity for bandwidth-contracts ? (manual only contains the range 256k - 2000M)
    Posted Jul 02, 2015 01:26 PM
    Rolf,
    It can certainly be configured in those increments.  Will everything be policed in such small increments?  Who knows...?  I suggest you try it out and report back to us.
