Hi All,
Setting up a GRE tunnel on a 7210 to talk to CPPM. Currently the client has Guest access running through VLAN 300 for their internal network on port GE0/0/0 ( with CCPM working ) and now they would like to send guest traffic to GE0/0/1 that has it's own internet connection to make it more secure. At this stage the controller is doing the DHCP and I have assigned the GE0/0/1 to VLAN 200.
The SSID is handing out IP's and I can ping the gateway ( currently the firewall ) but the problem arises when it tries to use the GRE tunnel to open the CPPM Login page. I followed the setup as per https://afp.arubanetworks.com/afp/index.php/ClearPass_GRE_Tunnel
If I set the Login page on the controller to the internal address of the GRE tunnel I get a "This webpage has a redirect loop" from chrome
If I use firewall rules to redirect the traffic down the tunnel and point the Login page to the IP on VLAN 300 it doesn't resolve.
The GRE tunnel says that it's up but i'm unsure how to test if traffic is traversing it or not, CPPM is receiving the MAC auth request but no other logs or requests
Hope this makes sence
Any input or feedback who be most helpful.
Marcus
#7210
