GRE L2 tunnel from Local to VRRP Master
  • 1.  GRE L2 tunnel from Local to VRRP Master
    Posted Dec 01, 2014 04:11 AM
    Dear all,
    i'm using AO 6.4.2.2.
    is it possible to configure a  layer 2 GRE Tunnel from local to vrrp ip address .
    if yes please tell me how , it very urgent.
  • 2.  RE: GRE L2 tunnel from Local to VRRP Master
  • 3.  RE: GRE L2 tunnel from Local to VRRP Master
    Posted Dec 01, 2014 05:12 AM
    thank you,
    in my case  i have 2 master controlleur
    master 1
    192.168.8.2
    master 2
    192.168.8.3
    master vrrp address
    192.168.8.1
    the local controller Address is
    192.168.8.120
    ******** master gre config*******
    interface tunnel 50
            description "Tunnel Interface"
            tunnel mode gre 50
            tunnel source 192.168.8.1
            tunnel destination 192.168.8.120
            trusted
            mtu 1400
            no inter-tunnel-flooding
            tunnel vlan 50,150-152
    **********local gre config*************
    interface tunnel 50
            tunnel mode gre 50
            tunnel source 192.168.8.120
            trusted
            mtu 1400
    it do not work for me
  • 4.  RE: GRE L2 tunnel from Local to VRRP Master
    Posted Dec 01, 2014 06:19 AM
    rchabourne,
    Have you tried setting it up with just a single VLAN, just between the local and the active master first?
  • 5.  RE: GRE L2 tunnel from Local to VRRP Master
    Posted Dec 01, 2014 10:07 AM
    when i configure a GRE tunnel between the local and the physical interface of the master (192.168.8.2) my GRE tunnel work normely but when i change the address with the VIP address  (192.168.8.1)  the GRE tunnel does not is not established
  • 6.  RE: GRE L2 tunnel from Local to VRRP Master
    Posted Dec 01, 2014 10:42 AM
    Please check you the post here http://community.arubanetworks.com/t5/Unified-Wired-Wireless-Access/L2-GRE-keepalive/m-p/188868/highlight/true#M38045
    Layer 2 GRE tunnel to a VRRP does work.
  • 7.  RE: GRE L2 tunnel from Local to VRRP Master
    Posted Dec 01, 2014 10:59 AM
    it have not work with me.
    do i need to actitvate keep alive
    in my case only one address is a VRRP and I'm using version 6.4.2.2 , it my be a bug
  • 8.  RE: GRE L2 tunnel from Local to VRRP Master
    Posted Dec 01, 2014 11:02 AM
    You do not have to use keepalives.  Where did you get tunnel mode GRE 50?
  • 9.  RE: GRE L2 tunnel from Local to VRRP Master
    Posted Dec 01, 2014 11:44 AM
    in theProtocole number  field , you have to chose an number between 0-65535, by the way what does it mean
  • 10.  RE: GRE L2 tunnel from Local to VRRP Master
    Posted Dec 01, 2014 05:17 PM
    You should probably open a case with TAC to ensure that nothing is being overlooked.  On the surface, nothing seems wrong with your configuration.
  • 11.  RE: GRE L2 tunnel from Local to VRRP Master
    Posted Dec 02, 2014 06:43 PM
    I just went through this with TAC and later my SE and a producline engineer he hooked me up with.
    In 6.3 anyway the problem stems from master-local traffic getting tunneled from the master VRRP address and therby messing with the master-local layer-2 traffic.
    We added another vrrp address to the masters and use that for the tunnel endpoint.
    Works like a charm.
    Master pair:
    master-redundancy
      master-vrrp 40
    vrrp 40
      ip address 10.21.0.64
    vrrp 41
      ip address 10.21.0.164
    interface tunnel 91
            tunnel source 10.21.0.164
            tunnel mode gre 0
            tunnel destination 10.30.0.9
    Local:
    interface tunnel 91
            tunnel source 10.30.0.9
            tunnel mode gre 0
            tunnel destination 10.21.0.164
  • 12.  RE: GRE L2 tunnel from Local to VRRP Master
    Posted Dec 03, 2014 05:54 PM
    Matthew
    it may be the cause of the problem especially that the local controller establishes an ipsec tunnel with the master controller, and with the GRE tunnel configured on the same IP address may cause  routing problem.
    because the controller in both cases will add a route to the same destination
    unfortunately my infra is flat (1 VLAN), so I can not create several vrrp  instence .
  • 13.  RE: GRE L2 tunnel from Local to VRRP Master
    Posted Dec 04, 2014 12:49 PM
    I made the same argument ;)
    Just add rhe second VRRP address to the same VLAN as the first. Seems odd, works fine.
