  • 1.  GRE Tunnel
    Posted Mar 13, 2013 05:16 AM
    Hi , I would like to calrify a basic query which may be very simple .
    If i have an AP - dual band dual radio . It is associated VAP which is broadcasting a single ssid with only a vlan . for example vlan 1. How many GRE tunnel will it form with controller?
    I am in assumption as it will have two BSSID as it has radio. Two GRE tunnel each one for a BSSID . Is my understanding correct?
  • 2.  RE: GRE Tunnel
    Posted Mar 13, 2013 06:26 AM
    ArubaOS_6.1 Guide
    "An AP opens a GRE tunnel to the controller for each radio interface."
    page 76
  • 3.  RE: GRE Tunnel
    Posted May 29, 2019 09:57 PM
    If there two VAP with dual-band AP, so how many GRE tunnel will be contruct?  2 ? or 5?.
    my assumption is 5 GRE tunnel:
            2 ssid + 2 radio + 1 keepalive = 5 , is this correct?
    any idea...
  • 4.  RE: GRE Tunnel
    Posted May 29, 2019 10:57 PM
    With AOS 6 or AOS 8 standalone, AOS 6 or 8 with HA, or with AOS 8 with the APs terminated on a cluster?
  • 5.  RE: GRE Tunnel
    Posted May 30, 2019 01:49 PM
    Since 6.1 documentation was mentioned, I will answer relating to that.
    There is a GRE per SSID per radio, along with a GRE for that AP heartbeat. If you have the 2nd Ethernet port enabled on your AP, then there is an additional GRE for the Ethernet port traffic.
    I hope this helps,
