GRE tunnel between AOS6900 and ArubaOS 6.4 ?
  • 1.  GRE tunnel between AOS6900 and ArubaOS 6.4 ?
    Posted Sep 30, 2014 03:04 PM
    Hi all,
    i want to configure GRE tunnel between AOS6900 and ArubaOS 6.4
    I have configuration as below. Although i create an ip tunnel on Aruba. But i ping it failed.
    is my configuration correct?
    Thanks all :)
    on Aruba:
    (OAW-4604) #show ip interface brief
    Interface                   IP Address / IP Netmask        Admin   Protocol
    vlan 999                   172.16.92.7 / 255.255.255.0     up      up
    vlan 1                      unassigned / unassigned        up      up
    vlan 100                     100.1.1.7 / 255.255.255.0     up      up
    vlan 1001                192.168.1.246 / 255.255.255.0     up      up
    loopback                    unassigned / unassigned        up      up
    mgmt                        unassigned / unassigned        down    down
    tunnel 1                    88.88.88.2 / 255.0.0.0         up      up
    (OAW-4604) #show interface tunnel 1
    Tunnel 1 is up line protocol is up
    Description: Tunnel interface
    Internet address is 88.88.88.2 255.0.0.0
    Source  192.168.1.246
    Destination 192.168.0.25
    Tunnel mtu is set to 1500
    Tunnel is an IP GRE TUNNEL
    Tunnel is Trusted
    Inter Tunnel Flooding is enabled
    Tunnel keepalive is disabled
    Keepalive type is Default
    (OAW-4604) #ping 192.168.0.25
    Press 'q' to abort.
    Sending 5, 100-byte ICMP Echos to 192.168.0.25, timeout is 2 seconds:
    Success rate is 100 percent (5/5), round-trip min/avg/max = 0.439/0.5234/0.686 m
    s
    i cannot ping its ip tunnel
    (OAW-4604) #ping 88.88.88.2
    Press 'q' to abort.
    Sending 5, 100-byte ICMP Echos to 88.88.88.2, timeout is 2 seconds:
    Success rate is 0 percent (0/5)
    (OAW-4604) #ping 88.88.88.1
    Press 'q' to abort.
    Sending 5, 100-byte ICMP Echos to 88.88.88.1, timeout is 2 seconds:
    (OAW-4604) #
  • 2.  RE: GRE tunnel between AOS6900 and ArubaOS 6.4 ?
    Posted Oct 01, 2014 12:07 AM
    You are referring to Alcatel 6900 switches?
  • 3.  RE: GRE tunnel between AOS6900 and ArubaOS 6.4 ?
    Posted Oct 01, 2014 04:59 AM
    yes. AOS6900 is omniswitch 6900
