Wired Intelligent Edge
GRE tunnel between two switches
  • 1.  GRE tunnel between two switches
    Posted Sep 13, 2018 08:18 PM
    Is it possible to create a tunneled node / GRE tunnel directly between two switches? The goal is something like this:
    vlan 7 ---- swtich A ---- itermediate routed network (no NAT) ------ Switch B ---- vlan 7 (same broadcast domain as the first.
  • 2.  RE: GRE tunnel between two switches
    Posted Sep 13, 2018 08:31 PM
    ArubaOS-Switch does not support GRE tunnels from switch to switch, only between Mobility controller to switch.
    Justin
  • 3.  RE: GRE tunnel between two switches
    Posted Sep 13, 2018 11:14 PM
    But it looks like VXLAN will achieve my goal similarly?
    NOTICE: The information contained in this e-mail, including any
    attachments, is confidential, intended only for the named recipient(s), and
    may be legally privileged. If you are not the intended recipient, please
    delete the e-mail and any attachments, destroy any printouts that you may
    have made and notify us immediately by return e-mail.
  • 4.  RE: GRE tunnel between two switches
    MVP GURU
    Posted Sep 14, 2018 01:54 AM
    Yes, it will be possible with VXLAN for this case
  • 5.  RE: GRE tunnel between two switches
    Posted Sep 14, 2018 02:23 AM
    But will that required jumbo MTU throughout the path.
  • 6.  RE: GRE tunnel between two switches
    Posted Oct 03, 2018 06:26 PM
    Hi Justin,
    And what about OS-CX v10.01?, does it support GRE tunnels from switch to switch?
    Regards
  • 7.  RE: GRE tunnel between two switches
    Posted Oct 03, 2018 06:40 PM
    Hi Pedro,
    Yes, ArubaOS-CX supports GRE tunnels. To route across the tunnels today you can choose between Static and BGP (OSPF will come soon).
    Regards, Ruben.-
  • 8.  RE: GRE tunnel between two switches
    Posted Oct 03, 2018 07:09 PM
    Thanks Ruben.
    What OS-CX configuration guide should I review to learn how to configure this?, there are many  manuals.
    Regards
  • 9.  RE: GRE tunnel between two switches
    Posted Nov 24, 2022 04:43 AM
    4 years later, same question, any documentation on this is ArubaOS-CX 10+? Probably searching for the wrong key words, but unable to spot anything.
  • 10.  RE: GRE tunnel between two switches
    Posted Nov 24, 2022 05:00 AM
    Check this guide - https://www.arubanetworks.com/techdocs/AOS-CX/10.10/HTML/ip_services_8400/Content/Chp_IP_tun/cre-gre-tun-tra-pub-net-10.htm
    Ivan Bondar
  • 11.  RE: GRE tunnel between two switches
    Posted Nov 25, 2022 02:42 AM
    that was quite easy indeed, thank you.
