GRE tunnel Issue
  • 1.  GRE tunnel Issue
    Posted May 11, 2020 10:08 AM
    Hi Team,
    We are having issue with gre tunnel the tunnel is not coming up.
    Topology:
    Two DMZ controllers
    Multiple Local controllers.
    Configuration is as below.
    On MD:
    *#show datapath session | include 10.112.60.248
    10.112.60.248 10.226.100.92 47 0 0 0/0 0 0 0 local 6 0 0 F 11
    10.226.100.92 10.112.60.248 47 0 0 1/0 0 0 0 local 6 1 64 FC 11
    *#show running-config | begin "tunnel 702"
    interface tunnel 702
    description "Tunnel Description"
    tunnel mode gre 27
    tunnel source 10.226.100.92
    tunnel destination 10.112.60.248
    tunnel keepalive
    trusted
    no inter-tunnel-flooding
    tunnel vlan 572-574
    On DMZ
    #show datapath session | include 10.226.100.92
    10.226.100.92 10.112.60.248 47 0 0 0/0 0 0 1 local 13 0 0 F 6
    10.112.60.248 10.226.100.92 47 0 0 0/0 0 0 1 local 13 2 180 FC 6
    tunnel mode gre 27
    tunnel source 10.112.60.248
    tunnel destination 10.226.100.92
    tunnel keepalive
    trusted
    tunnel vlan 572-574
    Mallikarjun
  • 2.  RE: GRE tunnel Issue
    MVP EXPERT
    Posted May 11, 2020 11:18 AM
    Can you post the output of 'show interface tunnel [ID]' and is there a firewall between the two controllers with the required IP protocol open?
  • 3.  RE: GRE tunnel Issue
    Posted May 11, 2020 12:49 PM
    Hi Craige,
    Thank you for the response.
    Please find the details below.
    #show interface tunnel 702
    Tunnel 702 is up line protocol is down
    Description: Tunnel Description
    Source  10.226.100.92
    Destination 10.112.60.248
    Tunnel mtu is set to 1100
    Tunnel is a Layer2 GRE TUNNEL
    Tunnel is Trusted
    Inter Tunnel Flooding is disabled
    Tunnel keepalive is enabled
    Keepalive type is Default
    Tunnel keepalive interval is 10 seconds, retries 3
            Heartbeats sent 797, Heartbeats lost 796
            Tunnel is down 2 times
    tunnel vlan 572-574
    as per the customer the firewall is open for gre protocol
    and also find the log below
    10.112.60.248   10.226.100.92   47   0     0      0/0     0    0   0   local       7    0          0          F               11
    10.226.100.92   10.112.60.248   47   0     0      1/0     0    0   0   local       7    1          64         FC              11
    Re
  • 4.  RE: GRE tunnel Issue
    Posted May 12, 2020 01:44 AM
    Hi Craig,
    Find the datapath tunnel table logs from both controllers.
    (HCAINNOI16F02DMZWLC02) #show datapath tunnel table | include 10.226.100.92
    9 10.112.60.248 10.226.100.92 47 1b 1100 0 0 0 0 0 0 00:00:00:00:00:00 0 223949 0 TLEFPRf
    (HTAINNOI21XXXWC01) *#show datapath tunnel table | include 10.112.60.248
