GRE Tunnel logistics
  • 1.  GRE Tunnel logistics
    Posted Aug 27, 2014 04:52 PM
    I currently have 2 remote sites, connected with a IPSEC tunnel to Aruba650s. I would like to create a similar connection to what I have with my RAPs where a user can join a remote vlan and be dumped directly on that vlan.  I think I would need to use GRE tunnels to accomplish this, however,  I am still not certian after reading some of the other forum posts.   It would seem if for example I wanted a wired user on the remote 650 to be placed on VLAN10 of the mainsite 650,  I would create the GRE Tunnel but then if I assign VLAN 10 to that Tunnel, it would send all VLAN10 traffic through that tunnel, which is fine for the remote site, but bad for the MainSite..  Am I misunderstanding the results or is there a different way to recreate that RAP experience?
    For reference I read this:
    http://community.arubanetworks.com/t5/ArubaOS-and-Controllers/Using-GRE-Tunnels-to-centralize-L3-access/td-p/2831/page/2
  • 2.  RE: GRE Tunnel logistics
    Posted Aug 28, 2014 04:49 AM
    I believe you can have the VLAN traffic associated to a port on the controllers at both sites. This would create a layer 2 subnet as if your controllers were acting as switches and the GRE a cable between the two. That way your wired user at the branch site could see devices logically connected on the other side of the controller port at the main site.
  • 3.  RE: GRE Tunnel logistics
    Posted Aug 28, 2014 01:42 PM
    I gave an example below,  any help on how to configure this like you recommended would be great.
    Campus 650
    Controller IP: 10.0.0.1
    Vlan: 100
    Vlan 100 IP: 192.168.0.1
    Remote 650
    Controller IP: 10.0.100.1
    Needs Vlan 100
  • 4.  RE: GRE Tunnel logistics
    Posted Aug 28, 2014 01:59 PM
    The config for th GRE link would be -
    Remote 650 -
    interface tunnel 100
            description "remote-to-campus"
            tunnel source 10.0.100.1
            tunnel mode gre 0
            tunnel destination 10.0.0.1
            trusted
            tunnel vlan 100
    campus 650 -
            description "campus-to-remote"
            tunnel source 10.0.0.1
            tunnel mode gre 0
            tunnel destination 10.0.100.1
            trusted
            tunnel vlan 100
    Then you just configure the physical ports at either end, access in VLAN 100 if you want to keep the VLAN separate, or as a trunk with VLAN 100 allowed.
