Aruba Central
GreenLake platform - SSO Integration with idp server
  • 1.  GreenLake platform - SSO Integration with idp server
    Posted Feb 01, 2023 06:07 AM
    Hi All,
    I am trying to setup a SSO login by using Keycloak idp server with HPE GreenLake platform.
    As per HPE Aruba documentation it is available only for Okta and Azure and not for Keycloak server.
    Anyone knows or did this type of SSO integration with your GLCP ?
    Please assist, I am working with TAC team currently but still not getting a solution.
  • 2.  RE: GreenLake platform - SSO Integration with idp server
    Posted Feb 06, 2023 04:47 AM
    If your Keycloak IdP supports SAML2, it should work if you return the same attributes/assertions.
    Did you get somewhere with TAC already? As this is a 'niche' scenario, in case you feel that the assigned engineer does not fully understand your case, ask for a case escalation.
  • 3.  RE: GreenLake platform - SSO Integration with idp server
    Posted Feb 07, 2023 12:24 AM
    Hi Herman,
    Thanks for your response!!!!
    I am working with TAC/ERT members currently and escalated to Aruba engineering team too.
    As of now there is no solution yet.
