Guest Access Best Practices
  • 1.  Guest Access Best Practices
    Posted Jan 15, 2013 06:21 PM
    14 IAP105s here.
    I'd like some best practice recommendation for a guest SSID.
    I see Airtime, Each User, and Each Radio as options to configure.
    The objective would be to limit the guest SSID from consuming all the bandwidth.  I'd like the other devices connected to other SSIDs to have the priority.
    If any has established a good fit for their environment, I'd like to hear your experience and approach.
    Thanks!
  • 2.  RE: Guest Access Best Practices
    Posted Jan 15, 2013 06:37 PM
    EDIT:
    Whoops...you have IAPs.  Forget what I typed.
