Guest Access e-mails and Office 365.
  • 1.  Guest Access e-mails and Office 365.
    Posted Aug 02, 2013 09:21 AM
    So we recently (Yesterday) switched to office 365. I was wondering if anyone had any experience with getting clearpass to send out e-mails using the cloud e-mail? Previously we had exchange 2003 set up and it used that, now that we've moved it's continuing to send it to our old accounts, and when I've updated the information on our new off-site SMTP on it, it doesn't send e-mails at all.
    Any help would be appreciated.
    Thanks!
    -Joshua
  • 2.  RE: Guest Access e-mails and Office 365.
    Posted Aug 02, 2013 09:25 AM
    In ClearPass guest under support, there is an application log.
    What's the error?
  • 3.  RE: Guest Access e-mails and Office 365.
    Posted Aug 02, 2013 09:26 AM
    Are you trying to do a raw SMTP relay? That may not be possible with cloud-based Exchange. You will most likely need to create a ClearPass mailbox and then get the SMTP settings for the mailbox from Outlook Web App under Settings > Options > See All Options > Account > Settings for POP and IMAP access.
    You could also try and add a local relay using IIS through an O365 mailbox. See below:
    http://support.microsoft.com/kb/2600912
  • 4.  RE: Guest Access e-mails and Office 365.
    Posted Aug 02, 2013 09:27 AM
    Function:  NwaSmtpSendMessage
    Arguments: array (
      'rtn' => array (
        'error' => 1,
        'message' => ' authentication failure [SMTP: SMTP server does not support authentication (code: 250, response: pod51020.outlook.com Hello [184.2.92.132]
        SIZE 36700160
        DSN
        AUTH)]',
  • 5.  RE: Guest Access e-mails and Office 365.
    Posted Aug 02, 2013 09:29 AM
    What Tim said! :-)
    Sent from my iPhone
  • 6.  RE: Guest Access e-mails and Office 365.
    Posted Aug 11, 2014 11:53 AM
    This does work by the way..
    These setting work for me just fine.
