Guest Access IAP
  • 1.  Guest Access IAP
    Posted Nov 24, 2016 09:19 PM
    Good Day!
    Is it possible to designate only 1 user or device can access to your created guest authetication.
    Scenario:
    I have created a guest SSID with a captive portal. Then I added the credentials User: Admin Password: Admin.
    Is it possible to limit that only one device can access that given credentials in the captive portal?
    Thanks and Best Regards,
  • 2.  RE: Guest Access IAP
    Posted Nov 24, 2016 11:16 PM
    it would not be possible without an external policy engine like ClearPass
