Guest access issue
  • 1.  Guest access issue
    Posted Sep 05, 2014 06:20 PM
    I have setuped a captive portal I used guest user and logged in and when I Disconnected from the network SSID guest and connect back again I was able to use the internet without the captive portal page?
  • 2.  RE: Guest access issue
    Posted Sep 05, 2014 06:21 PM
    You are still in the user-table until the user-idle timer expires which means you can reconnect without re-authenticating. This is how L3 authentication works with captive portals.
