Guest Access License
  • 1.  Guest Access License
    Posted Feb 15, 2014 08:34 AM
    If i want guest access function  for 100 Guest user , i have 3 options :
    1- Just Buy "LIC-CP-GM-100" ... is this true ?   no other license needed for ClearPass Policy Manager  itself ?
    2-  Buy "CP-HW-500" , in this case do i need to buy the above license as well ?
    3- Buy "CP-VA-500" , in this case do i need to buy the above license as well ?
    Finally
    1- what does enterprise license include ?
     LIC-CP-EN-xxx* : Enterprise License for ClearPass Policy Manager
    2- What is difference between  CP-HW-500  & CP-VA-500  ?  bot are hardware provided from Aruba ?
  • 2.  RE: Guest Access License
    Posted Feb 15, 2014 08:42 AM
    Enterprise allows you to use the combination of different clearpass modules : policy manager, guest , onboard , onguard.
  • 3.  RE: Guest Access License
    Posted Feb 15, 2014 09:44 AM
    CP-HW-500 is a hardware appliance that you buy from Aruba
    CP-VA-500 is a VMWare virtual appliance that you deploy in your virtualization infrastructure. It is provided as an OVA.
  • 4.  RE: Guest Access License
    Posted Feb 15, 2014 09:56 AM
    Thx
  • 5.  RE: Guest Access License
    Posted Feb 15, 2014 09:59 AM
    You need to buy the base ClearPass appliance (whether virtual or physical) and then add on the guest license (it’s a module for the base product).
    Sent from Surface Pro
  • 6.  RE: Guest Access License
    Posted Feb 15, 2014 01:06 PM
    Thx
    so i cann't get only "LIC-CP-GM-100"  & install it on my sever ?   HW or VA purchase is a must with the license ?
  • 7.  RE: Guest Access License
    Posted Feb 15, 2014 01:11 PM
    No you can't. That license simply enables the guest functionality on your
    CPPM server.
