Guest access on controller
  • 1.  Guest access on controller
    Posted Sep 19, 2013 09:37 AM
    I have a question regarding session times - guest users are getting logged out after 30mins, captive portal is on controller running 6.1.3.8. The user guide says - "the user remains logged in until the user timeout period has elapsed" but there is no details if this refers to a specific timer and what the default might be. Its under the section for "logout popup window" so it may only refer to this situation. Is there a default session limit for guests?
  • 2.  RE: Guest access on controller
    Posted Sep 19, 2013 09:50 AM
    Under the advanced tab in AAA profile, you will find the user timeout.
  • 3.  RE: Guest access on controller
    Posted Sep 19, 2013 10:08 AM
    I must be looking in the wrong place, under the AAA profile there is no advanced tab displayed, there is one under Security>Authentication>Servers but it looks like only server authentication timeout values are configured here.
  • 4.  RE: Guest access on controller
    Posted Sep 19, 2013 10:13 AM
    Check that advanced tab as soon as you check security from the left menu...what is that idle timeout value?
  • 5.  RE: Guest access on controller
    Posted Sep 19, 2013 11:34 AM
    I dont have access to the controller at the moment, but I assume its the default 5mins as I did not change it, but isnt this as it says on the tin - an "idle timeout", the question was regarding a maximum session limit time.
  • 6.  RE: Guest access on controller
    Posted Sep 20, 2013 08:44 AM
    This might help you :
    (controller) #show web-server
    Web Server Configuration
    Parameter Value
    Cipher Suite Strength high
    SSL/TLS Protocol Config sslv3 tlsv1
    Switch Certificate default
    Captive Portal Certificate default
    Management user's WebUI access method username/password
    User session timeout <30-3600> (seconds) 900
    Maximum supported concurrent clients <25-320> 320
    Enable WebUI access on HTTPS port (443) false
