Guest Access reference CSS in Captive Portal
  • 1.  Guest Access reference CSS in Captive Portal
    Posted Jul 16, 2012 02:56 PM
    Would it be possible to reference external css/image files on my Captive Portal? The goal would be to easily make small tweaks to the layout without needing to upload new files constantly.
    Instead of:
    <link href="/auth/custom/styles.css" rel="stylesheet" media="screen" type="text/css">
    I want:
    <link href="http://www.exampledomain.com/styles.css" rel="stylesheet" media="screen" type="text/css">
    Thanks for any input!
  • 2.  RE: Guest Access reference CSS in Captive Portal
    Posted Jul 16, 2012 05:23 PM
    I don't think this is possible. I have tried to do it in the past, but it doesn't work or you can say it is not supported. It is security risk for controller's web server.
    -Alap
