do you know if is possible to disconnect a guest user with CoA fonctionnality (RFC 3576) on RAP-3WN Wired Port ?
Thks
Yann
Yes, If you have the port untrusted and have a aaa profile configure
Thanks you for your answer but i have forgot to specify that concern a RAP-3WN in IAP mode ...
Ok thanks you ;)
