Guest access through CP stops working after 1-2 hrs can be corrected by rebooting the controllers (3400 running 6.1.3.7) any ideas where to look to see why it stops working? The CP captures email addr only to auth and allow access.
hah thats a good one...
Now you say that i think i didnt put DHCP on the post authenticated role the any dhcp, on my last installation a few days ago... and now you put me thinking... willl check on all the WC i have installed for this
Colin's suggestion sounds likely. Even if you have dhcp allowed, check to see if you have a "block rogue dhcp" acl in place somewhere that is incorrect. I often see rules set with any any udp 68 deny instead of user any udp 68 deny.
