Guest Access with Facebook Authentication
  • 1.  Guest Access with Facebook Authentication
    Posted Apr 23, 2018 03:55 PM
    Hello
    Thanks in advance for any help you can provide. I have a dell aruba controller that we are wanting to use facebook to authenticate our guest network on. I was wondering if anyone could give me an idea of where to start on this. I just took this appliance over so I am very new to it. Thanks
  • 2.  RE: Guest Access with Facebook Authentication
    Posted Apr 23, 2018 03:56 PM
    I forgot to mention that we do not want to use clearpass in any way on this due to lisc. issues. Thanks
  • 3.  RE: Guest Access with Facebook Authentication
    Posted Apr 23, 2018 04:05 PM
    The Aruba hardware controller does not have a Facebook interface and would require and external Captive Portal like ClearPass that supports Facebook integration.
  • 4.  RE: Guest Access with Facebook Authentication
    Posted Aug 29, 2018 07:50 AM
    What are the Prerequsites and can you let me know if there any documets have instruction to configure the facebook authentication.
    Ranji
  • 5.  RE: Guest Access with Facebook Authentication
    Posted Aug 31, 2018 07:21 AM
    This should help:
    https://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/How-to-Configure-Facebook-WIFI-with-Aruba-controller-and/ta-p/270518
  • 6.  RE: Guest Access with Facebook Authentication
    Posted Sep 01, 2018 02:40 AM
    Dear Charlie,
    Many thanks for prompt response.
    Let me go through and update you.
    Once again thanks.
    Ranji
  • 7.  RE: Guest Access with Facebook Authentication
    Posted Nov 26, 2018 03:42 PM
    I have an IAP cluster and I configured Facebook Splash page type in Security option but the login is opened, the system doesn´t require a check-in. Is it a correct behavior? What could be happening?
