Guest Authentication Failed (Clearpass)
  • 1.  Guest Authentication Failed (Clearpass)
    Posted Jun 05, 2017 03:17 PM
    Hi All,
    I am working on Clearpass guest, i implemented all the scenario but the issue is when i am trying to login by username and password i received an error "Authentication Failed". I tried to create a new account from the same login page and the account was created successfuly as i confirmed from the CPPM.
    But when i tried to login with the same username and password again i received the same error. Below are the sanpshots from the configuration i did.
    1. Group = Universities
    2. VAP = guest_uni_vap_pro
    3. AAA Profile = guest_uni_aaa_pro,
    SSID Profile = guest_uni_ssid_pro
    4. AAA initial Role = guest_uni_aaa_init_role
    5.  user role guest_uni_aaa_init_role
    access-list List
    Position Name Type Location
    1 global-sacl session
    2 apprf-guest_uni_aaa_init_role-sacl session
    3 logon-control session
    4 cppm_red_acl session
    5 captiveportal session
    6. Default Role (L3 Authentication)
    access-list List
    Please support me.
  • 2.  RE: Guest Authentication Failed (Clearpass)
    Posted Jun 05, 2017 03:25 PM
    For guest, you should not have an 802.1X server group defined.
    The ClearPass server-group should be defined in your captive portal profile.
  • 3.  RE: Guest Authentication Failed (Clearpass)
    Posted Jun 05, 2017 03:51 PM
    Thanks Cappalli,
    I checked my configuration and i found that i didn't add Captive Portal Profile in L3 Authentication Default Role. I added but the repsonse is same authentication failed. Below are the snapshots for your review.
  • 4.  RE: Guest Authentication Failed (Clearpass)
    Posted Jun 05, 2017 03:56 PM
    Your Mac auth server group shows default. Should be your cppm server
  • 5.  RE: Guest Authentication Failed (Clearpass)
    Posted Jun 05, 2017 04:07 PM
    I added the MAC Authentication Server Group but the facing same issue. 8.JPG
  • 6.  RE: Guest Authentication Failed (Clearpass)
    Posted Jun 06, 2017 04:32 AM
    Waseem,
    Could you share authentication failed access tracker log, if it is not possbile , please open TAC ticket.
    Pavan
  • 7.  RE: Guest Authentication Failed (Clearpass)
    Posted Jun 06, 2017 04:47 AM
    Hi Pavan,
    Thanks for reply. Actually i didn't see any thing in the Access Tracker. I didn't see any authentication request hits the clearpass. If you check my first post there i mentioned that the user is created successfuly but the problem is authentication failed but here the strange thing is i didn't not see any thing in the access tracker and no authentication hits the clearpass.
  • 8.  RE: Guest Authentication Failed (Clearpass)
    Posted Jun 06, 2017 05:21 AM
    I have attached clearpass and aruba wireless integration guide which provide steps for .1x and Guest authentication.
    I understand that authentication request itself not coming on to CPPM, have you added controller IP to clearpass?
    If you have added controller ip in cppm then something configuraiton mismatch on controller, check the Tech document.
    Pavan
    If my post addresses, your query give kudos:)
  • 9.  RE: Guest Authentication Failed (Clearpass)
    Posted Jun 06, 2017 05:26 AM
    Thanks for the Guide. I follow the same guide during configuration. Now i don't have access to controller and clearpass, today i will cross check and update you.
  • 10.  RE: Guest Authentication Failed (Clearpass)
    Posted Jun 07, 2017 04:03 PM
    If you are not getting any hit in access tracker then please check event viewer in Clearpass.
  • 11.  RE: Guest Authentication Failed (Clearpass)
    Posted Jun 07, 2017 04:47 PM
    Hi Milind,
    Thanks to you and all who support me. My problem was resolved, actually that time i did not configure clearpass guest web login and i did not added the MAC Authentication Server.
