Guest captive portal
  • 1.  Guest captive portal
    Posted Feb 13, 2015 06:26 AM
    Hi all,
    Is there any option to force the user to accept the T&C in guest captive portal to get access in internet.
    Means I dont want a open SSID and users will connect to that SSID the user will reddirect to the captive portal page and after that user has to accept the T&C to access the internet. [No password, user name or email. the only key to get the access is accept the policy ]
    There is no  CPPM.
  • 2.  RE: Guest captive portal
    Posted Feb 13, 2015 06:34 AM
    In the Captive Portal Authentication profile you can:
    - Uncheck "User Login"
    - Uncheck "Guest Login"
    - Check "Show the acceptable use policy page"
    or...you can make your own page:
    http://community.arubanetworks.com/t5/Controller-Based-WLANs/What-do-I-need-to-change-in-the-HTML-code-of-a-customized/ta-p/178268
  • 3.  RE: Guest captive portal
    Posted Feb 13, 2015 07:23 AM
    Thanks its working.
  • 4.  RE: Guest captive portal
    Posted Feb 18, 2015 03:27 AM
    Sorry for the delay,
    I designed my own CP page from https://arubanetworkskb.secure.force.com/pkb/articles/HowTo/R-154
    But there is only accept button,No decline option. I dig around all the aruba site but no luck.
    I think its becuase of Aruba controller dont have DECLINE [only accept] option. The only things we can achieve is ACCEPT the T&C.
    Please correct me if I wrong.
